2025.1
Engine Keyword In this group keywords are used to generally define the output style, control of computation, damping and ALE setup during the computation.
View new features for Radioss 2025.1.
Current Radioss format uses the 12x extension format.
Engine Keyword Generates animation files in Radioss environment post-processing formats 41 and 44.
Engine Keyword This keyword has to be set at the end of the Engine input deck when using Single File Input.
Engine Keyword Generates the Time History files in Radioss environment post-processing format "Version Number".
Engine Keyword Input a title.
Engine Keyword Identifies the input data version number.
Engine Keyword In this group, keywords are used for modification (deletion or add options) in Engine.
Generates animation files containing results according to the keywords specified. The keywords are specified in the topics within Animation and Post-processing Output Files.
Engine Keyword In this group keywords are used for implicit solution. Different implicit solver methods (linear, nonlinear, buckling or quasi-static), different options to control the implicit computation, different implicit time step method and implicit output messages are introduced.
Engine Keyword In this group, keywords are used to define the kinematic condition (constrain/release rotation or translation DOF) and initial condition (rotational/translational velocity).
Engine Keyword In this group, keywords are used to define different time step control (STOP, KILL, CST or DEL, and so on) for different entities (shell, brick, beam, airbag, interface, and so on) during the computation.
Engine Keyword In this group, keywords are used to output different info (like stress, strain, orthotropy direction, temperature, and so on) in a state file (STA-File).
This manual provides a list of LS-DYNA input files available in Radioss.
This manual contains the description of the keywords for the Radioss Multi-Domain.
Keywords that are still supported, but no longer maintained (*) are considered obsolete.
