Starter Subroutine USERWIS
This subroutine reads the input data.
You can specify the number of cards and their format.
Arguments
The argument list of
USERWIS
and its individual arguments and
descriptions
are:C-----------------------------------------------------------------------------------------
SUBROUTINE USERWIS(IIN ,IOUT ,NUMNOD ,ITAB ,
. X ,V ,VR ,MASS ,INER ,
. NUVAR ,NUVARI ,UVAR ,IUVAR )
Definition
Argument | Format | Description |
IIN |
Integer read only scalar | Input file unit (Starter input file) on which the data are read. |
IOUT |
Integer read only scalar | Output file unit (Starter output file). |
NUMNOD |
Integer scalar | Number of nodes (defined with /NODE option). |
ITAB(NUMNOD) |
Integer array | An array of size NUMNOD . This defines the
node ID versus Radioss internal node
number. |
X(3,NUMNOD) |
Float array | Nodal coordinates. |
V(3,NUMNOD) |
Float array | Nodal initial coordinates. |
VR(3,NUMNOD) |
Float array | Nodal initial rotational velocities. |
Mass(NUMNOD) |
Float array | Nodal mass. |
INTER(NUMNOD) |
Float array | Nodal spherical inertia. |
NUVAR |
Integer scalar | Needed size of global user float array. |
NUVARI |
Integer scalar | Needed size of global user integer array. |
UVAR(MAXNUVAR) |
Float array | An array of size MAXNUVAR in Radioss Starter. This array is
transmitted via the restart file to Radioss Engine, where it has a size of
NUVAR . |
IUVAR(MAXNUVARI) |
Integer array | An array of size MAXNUVARI in Radioss Starter. This array is
NUVARI . |
