/H3D/SOLID
Engine Keyword Generate H3D contour output results for /BRICK, /BRIC20, /TETRA4, /TETRA10 solid elements and /BRICK, /PENTA6, /SHEL16 thick shells.
/H3D/SOLID/Keyword3/Keyword4/Keyword5
#optional next line(s) that lists the parts to save results for.
part_ID1... part_IDN
Definition
| Keyword3 | Output types. | |
| Keyword4 | Output types. | |
| Keyword5 | Output types. | |
| part_IDN | Optional list of part IDs for which results will be output. |
| Keyword3 | Keyword4 | Keyword5 | Description |
| AMS | Elements using AMS timestep due to /DT/CST_AMS. | ||
| DAM1, DAM2, DAM3 | Principal damage values in local cracking skew direction 1, 2 or 3 for material LAW24 with /BRICK elements. | ||
| DAMA |
Maximum damage over time of all
/FAIL criteria acting on one
material. If Keyword4 is blank, the maximum integration point value in the element is output. Refer to the specific /FAIL law used for how damage is calculated. |
| TMAX | Maximum damage over time, integration points and failure models. | ||
| DAMG |
Mean damage over integration points (only for coupled damage models). 4 | |
Damage modes for the given material
mat_ID as global damage or for each damage model (adding
MODE= I or ALL). (for MODE output, refer to Comment 7) Available for materials LAW2, LAW25, LAW36, LAW72, LAW76, LAW79, LAW83, LAW104 + /FAIL/GURSON, LAW116, LAW117, LAW120, LAW122, LAW124. |
| DAMINI |
Maximum damage initiation variable among all failure criteria using initiation variable before computing stress softening (/FAIL/INIEVO). | |
| DENS | Density | ||
| DOMAIN | SPMD domain number of an element. | ||
| DT | Element timestep | ||
| EINT | Internal energy ( eV) | ||
| EINTM | Specific internal energy (e) | ||
| EINTV | Internal energy density ( e) | ||
| ENER | Specific energy density (internal energy divided by the element mass) | ||
| TMAX | Maximum specific energy density over time | ||
| ENTH | Enthalpy (e+pV) | ||
| ENTHM | Massic enthalpy (e + pV) / m | ||
| ENTHV | Enthalpy density (e/V +p) | ||
| EPSD | Equivalent strain rate | ||
| EPSP | Plastic Strain | ||
| FAILURE | ID= fail_ID or ALL (mandatory) MODE=I or ALL |
Damage of a specific failure
criterion references by its optional identifier fail_ID defined in the Starter file. (for MODE output, refer to Comment 7) |
| FILL | Filling percentage for /INIBRI/FILL | ||
| FLDF | OUTER OUTER_AVERAGE |
FLD damage factor indicator. 5 | |
| FLDZ | OUTER OUTER_AVERAGE |
FLD failure zone factor for the FLD
failure model.
| GROUP | Internal group identifier | ||
| HOURGLASS | Hourglass energy per mass unit | ||
| MASS | Element mass | ||
| MDS | MDS user
variables. Automatic selection of user variable to output according to MDS law that is used. (mean value with all solid integration points) |
MDS user
variables. (mean value with all solid integration points) |
| NL_EPSD | Non-local plastic strain rate (only if /NONLOCAL/MAT is activated) 5 | ||
| NL_EPSP | Non-local plastic strain (only if /NONLOCAL/MAT is activated) 5 | ||
| OFF | Element status. Where the result
output is:
| ORTHD |
Euler angles in degrees defining
the rotation matrix to go from global reference system to
orthotropic reference system. To request a specific angle use ORTHD/PSI, ORTHD/THETA, or ORTHD/PHI. |
| P | Pressure | ||
| PEXT | External pressure applied on solid
element coming from /LOAD/PCYL,
/PLOAD, /LOAD/PFLUID,
/LOAD/PBLAST or
/LOAD/PRESSURE. The outer skin is automatically created to display the pressure. |
| SIGEQ | Equivalent stress based on a material’s yield criteria. Some examples of yield criteria are von Mises, Hill or Barlat. | ||
| TMAX | Maximum equivalent stress based on a material’s yield criteria over time. | ||
| SIGX, SIGY, SIGZ, SIGXY, SIGYZ, SIGZX | Mean element stress in specified direction. | ||
| TEMP | Temperature | ||
| TDEL | Time at which element is deleted due to failure defined using /FAIL criterion. Failure criteria built in materials is ignored. | ||
| THICK | Average thickness for thick-shell elements (/PROP/TYPE20, /PROP/TYPE21, /PROP/TYPE22). | ||
| THIN | Average % thinning for thick-shell elements (/PROP/TYPE20, /PROP/TYPE21, /PROP/TYPE22). | ||
| TILLOTSON | Region identifier for Tillotson Equation of State (/EOS/TILLOTSON) | ||
| TSAIWU | Tsai Wu criterion for material /MAT/LAW12 (3D_COMP), /MAT/LAW14 (COMPSO) and /MAT/LAW25 (COMPSH) | ||
| USER |
User material (/MAT/USERij) law output for user-defined variable i. Also, requests USR output for some Radioss material laws such as LAW59 or LAW70. USR1 output is requested using UVAR=1. For integration point results, use IR, IS and IT options. | |
| VDAM1 |
Value of damage factor D, for /FAIL/SNCONNECT. | |
| VDAM2 |
Value of damage surface for /FAIL/SNCONNECT. | |
| VDAM3 |
Value of rupture surface for /FAIL/SNCONNECT. | |
| VONM | Mean element von Mises stress | ||
| TMAX | Maximum mean element von Mises stress over time. | ||
| VSTRAIN | Volumetric strain | ||
| VSTRAIN/I | Volumetric strain for each volume fraction I (for ALE multi-material laws: LAW20, LAW37, LAW51 and LAW151) | ||
| WPLA | Plastic work for /MAT/LAW12 (3D_COMP) and /MAT/LAW25 (COMPSH) |
| Keyword3 | Keyword4 | Description |
| BFRAC | Burn fraction | |
| BULK | Artificial viscosity | |
| COLOR | 1*vfrac1 + 2*vfrac2 + .... + last*vfracN (LAW51 and LAW151 only). | |
| DIV(U) | Volumetric dilatation rate | |
| K | Specific for turbulent energy in CFD. | |
| MACH | Mach number (/MAT/LAW151 only) | |
| MOM | Cell momentum Density (MOM) for FVM with Interface TYPE22 for all components and magnitude. To request each separately use, MOMX, MOMY, MOMZ, MOMXY, MOMYZ, MOMXZ, |MOM|. | |
| SCHLIEREN | Schlieren image (optical method widely used in CFD field). ALE material laws. | |
| SSP | Sound speed. Only available with ALE material laws. | |
| TDET | Detonation time output. | |
| TVIS | Specific for turbulent viscosity in CFD. | |
| VEL | Cell velocity for FVM with Interface TYPE22 for all components and magnitude. To request each separately use, VELX, VELY, VELZ, VELXY, VELYZ, VELXZ, |VEL|. | |
| VFRAC | All volumetric fractions (for ALE multi-material laws: LAW20, LAW37, LAW51 and LAW151). | |
| VFRAC1,VFRAC2, VFRAC3,VFRAC4 | Volumetric fractions (for ALE multi-material laws: LAW20, LAW37 and LAW51). | |
| VORT, VORTX, VORTY, VORTZ | Vorticity for ALE material in resultant, X, Y, and Z components. | |
| VECT | VEL | Velocity vectors at finite volume cell centroids. |
| CONT | Contact force vectors at finite volume cell centroids. | |
| ACC | Acceleration vectors at finite volume cell centroids. |
| TENS | BSTRESS |
Backstress tensor for material
/MAT/LAW36 (n=1) and
/MAT/LAW78 (n=1, 2 or
3). ID=-1 returns the sum of all backstress tensors available for the element. |
| DAMA | Cracks tensor at integration points
for Material LAW24 only. If Keyword5 is blank, the mean value in the element is output. |
| EPSP |
Plastic strain tensor at
integration points, only available for
/MAT/LAW24 with
Icap=2. If Keyword5 is blank, the mean value element is output. |
| STRAIN |
Strain tensor at integration
points. If Keyword5 is blank, the mean value in the element is output. |
| TMAX | Strain tensor corresponding to the
maximum principal strain (P1) over time and integration
points. Strain tensor corresponding to the minimum principal strain (P3) over time and integration points. |
| OUTER | Membrane strain tensor on the outer surface of a solid or thick shell component. The membrane layer is automatically created, and the solid strain tensor is extrapolated to this surface. | ||
| OUTER_AVERAGE | Average membrane strain tensor between the two outer surfaces of a thick shell component. The membrane layer is automatically created, and the thick shell strain tensor is extrapolated to this surface. | ||
| CORNER_DATA | Strain tensor saved for all nodes of each element (not available for /SHEL16 or /BRICK20). | ||
| STRAIN_ENG | -- | Infinitesimal total strain. Only one tensor per element. | |
| STRESS |
Stress tensor at integration points. If Keyword5 is blank, the mean value in the element is output. | |
| TMAX | Stress tensor corresponding to the
maximum principal stress (P1) over time and integration
points. Stress tensor corresponding to the minimum principal stress (P3) over time and integration points. |
| OUTER | Membrane stress tensor on the outer surface of a solid or thick shell component. The membrane layer is automatically created, and the solid stress tensor is extrapolated to this surface. | ||
| CORNER_DATA | Stress tensor saved for all nodes of each element (not available for /SHEL16 or /BRICK20) |
/H3D/SOLID/TENS/STRESS/IR=1/IS=2/IT=1
/H3D/SOLID/TENS/STRESS/IR=ALL/IS=ALL/IT=ALL/H3D/SOLID/ENER
1 55 75Comments
- The syntax /H3D/ELEM/Keyword3/Keyword4/Keyword5 is also valid.
- When PART IDs are listed after the /H3D/SOLID line the specified results will only be output for those parts.
- To request integration point results, use /IR=i/IS=j/IT=k notation where the options can be entered in any order.
- Option DAMG is
only used with coupled damage models (such as /MAT/LAW72 or
/FAIL/GURSON) to output damage over integration points.
The damage variable is normalized by its critical value to get values between 0
and 1. For instance:
- For /MAT/LAW72
- For /FAIL/GURSON
- For /MAT/LAW72
- If /NONLOCAL/MAT option is activated, it is possible to output the regularized non-local plastic strain and its rate.
- The damage initiation variable /H3D/SOLID/DAMINI is used with some failure criteria such as /FAIL/INIEVO, which first computes a damage initiation criterion before computing the stress softening damage variable, which can be plotted with /H3D/SOLID/DAMA.
- For failure criteria using different modes (mainly for composites), such as /FAIL/HASHIN, /FAIL/CHANG, and so on, these different modes can be output using the /H3D/SOLID/FAILURE option with the keyword MODE. You can choose to plot a specific mode using its number I (refer to the failure criterion documentation for mode number details), or all modes with ALL. The option MODE can be combined with LAYER and IR, IS, IT output keywords.
