/INCMP (Obsolete)
Engine Keyword Quasi-incompressible formulation for fluid material (compatible with /MAT/LAW6 and /MAT/LAW11).
/INCMP
  1. This option should not be used when non-fluid materials are present, or if k ​ − ​ ε turbulence or heat transfer are active.
