ALE Formulation
ALE or Arbitrary Lagrangian Eulerian formulation is used to model the interaction between fluids and solids; in particular, the fluid loading on structures. It can also be used to model fluid-like behavior, as seen in plastic deformation of materials.
ALE derives its name from a combination of two different finite element modeling techniques.
  • Lagrangian Formulation - where the observer follows material points.
  • Eulerian Formulation - where the observer looks at fixed points in space.
  • Arbitrary Lagrangian Eulerian Formulation - where the observer follows moving points in space.
