2025.1
Set up your model and run a structural analysis or optimization.
Discover new features and enhancements.
New to Inspire? Learn the basics here.
Start using Inspire with our interactive tutorials.
Create and assign variables to parametrize a model. This allows you to quickly iterate and compare design concepts by tweaking the values of the variables.
Create parametric sketches, geometry, and PolyNURBS with construction history and variables.
Create implicit models with primitives, lattices, point clouds, fields, offsetting, Booleans, inverting, smoothing, morphing, and filleting.
Create connections and apply loads, constraints, materials, and manufacturing controls to your model.
Set up and run a linear static analysis using the SimSolid or OptiStruct solver. You can also analyze normal modes and buckling modes.
Set up and run a topology, topography, or gauge optimization.
Generate PPT or PDF reports from analysis results. The Report tools are available after you have run an analysis.
Set up and run a motion analysis, plot the results, and export the results.
Prepare and run a computational fluid dynamics simulation.
Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method. We recommend fully constraining your sketch when sketch variables are used in the design exploration.
Set up and run a basic porosity or thinning analysis.
Prepare and run an additive manufacturing simulation, and export a file for 3D printing.
Adjust the materials and environment of objects in the scene to create a photorealistic image.
Learn how to access the Inspire Python API including online help, quick start demos, and the Extension Manager.
View the glossary, frequently asked questions, and errors and alerts.
Learn keyboard shortcuts and mouse controls for common operations.
