Automatic Parameterization
Workbook designers set this property in the Dashboard and Workbook Settings pane.
- On
When turned on, parameters can be automatically updated within a dashboard by right-clicking on a visualization item and selecting it from the context menu with the blue lightning icon.
The dashboard parameter values to be passed will include all possible data table values of the selected visualization.
For example, if there are Region and Industry dashboard parameters, and the associated data table of the visualization has a Region but no Industry column, then the Automatic Parameterization option will only include:
However, if the associated data table of the visualization has Region and Industry columns, then the Automatic Parameterization option will include both:
- Off
Automatic parameterization on the visualization based on the dashboard parameters is turned off.
In some circumstances, it may be appropriate to disable this automatic parameterization, and instead utilize more configurable navigation actions.
- Inherit
The automatic parameterization is inherited from the workbook property.
(c) 2024 Altair Engineering Inc. All Rights Reserved.
