SS-T: 1076 Curved Composites
Tutorial Level: Intermediate
Purpose
SimSolid performs meshless structural analysis that works on full featured parts and assemblies, is tolerant of geometric imperfections, and runs in seconds to minutes. In this tutorial, you will do the following:
  • Learn how to create laminates for curved and protruded geometries in SimSolid
    Note: Version 2025.1 supports laminates with orthotropic material for flat, curved and revolved parts.
Model Description
The following model file is needed for this tutorial:
  • Fuselage.x_b
Figure 1 shows the fuselage model used for this tutorial. The stringers and the skin of the fuselage are imported as CAD surfaces, whereas the frames are imported as solid sheets. In this tutorial, you will create laminates for the curved skin and the protruded stringers.
Activate Import Solids and skins
  1. Launch a new SimSolid session.
  2. In the main menu, click Settings > Geometry Import settings.
  3. Set the Resolution to Fine.
  4. For Import geometry type, select Solids and skins from the dropdown.
  5. Click OK.
Import Geometry
  1. Open a new SimSolid session.
  2. Click Import from file .
  3. In the Open geometry files dialog, choose Fuselage.x_b.
  4. Click Open.
    The assembly will load in the modeling window.
Review CAD Assembly
  1. Right-click on the assembly in the Project Tree, and then select Info.
    The Assembly info dialog opens displaying the 9 skin parts.
  2. To isolate the 9 skin parts, right-click on the assembly and select Show > Skins.
Create Orthotropic Material
  1. In the main menu, click Settings > Material database.
  2. Ensure View materials from is set to Material database.
  3. Right-click on Generic Materials and select Add material in the context menu.
  4. Enter the material name and values as shown in the below figure.
    Figure 3.
  5. Click Apply.
  6. Click Save.
Create Laminates for Stringers
  1. In the Assembly workbench, click Create Laminate.
  2. To add a skin in the Create laminate dialog, select one of the stringer parts from the Project Tree or modeling window.
  3. For Stack direction, select Top from the dropdown.
    Top
    Stacks the plies along the direction of the reference plane as shown in graphics.
    Bottom
    Same as Top but on the other direction of its reference plane.
  4. Click Edit under Reference direction (R-dir).
    1. Ensure the axes X, Y, Z are set to 0, 0, -1 respectively.
      Note: SimSolid automatically picks the axis based on the selected skin. Reference direction is set along the length for the protruded parts and parallel to the axis of rotation for curved parts. For flat parts it is along the lengthier side of the selected skin, which can be edited. Reference direction cannot be set normal to the selected skin.
    2. Click OK.
  5. To add a ply, click Add ply in the ply stack section. Add 3 plies.
  6. Change the thickness of Ply 1, 2, and 3 to 0.1mm, 0.2mm, and 0.2mm respectively.
    Note: Each field in the ply stack section can be made editable by double-clicking on the respective field.
  7. Click Select Material to apply material for all the three plies.
    1. In the Apply material to Laminate plies dialog, select the Material database radio button.
    2. Select Composite from the list and click Apply material.
  8. Set the Orientation for Ply 1, 2, and 3 as 0, 45, 90 degrees respectively.
  9. Review total Stack thickness and Approximate stack mass shown at the bottom of the dialog.
  10. Click OK.
Figure 4.
Create Laminates for Fuselage Skin
  2. To add a skin in the Create laminate dialog, select the part named Skin from the Project Tree or modeling window.
  3. Click Edit under Reference direction (R-dir).
    2. Click OK.
  4. For Stack direction, select Bottom from the dropdown.
    Top
    Bottom
  5. To add a ply, click Add ply in the ply stack section. Add 4 plies
  6. Change the thickness of Ply 1, 2, 3, and 4 to 0.2mm, 0.3mm, 0.3mm, and 0.2mm respectively.
  8. Set the Orientation for Ply 1, 2, 3, and 4 as 0, 90, 0, and 90 degrees respectively.
  9. Optional: Select Show ply orientation to view the applied orientation to the laminate.
    Figure 5.
  10. Review total Stack thickness and Approximate stack mass shown at the bottom of the dialog.
  11. Click OK.
Figure 6.
Review Laminates and Connections
  1. In the Project Tree, expand the assembly. The skins are now identified as a laminates. Expand the laminate folder to view the plies and their properties.
  2. In the Project Tree, expand Connections > Precise connections.
    Note: Precise connections are automatically created between the plies of the laminate.
Apply Material to Remaining Parts
  1. Right-click on the assembly in the Project Tree, and then select Show ➔ Parts without material.
    The parts without material are isolated in the modeling window.
  2. Select the parts by click and drag selection in the modeling window.
  3. In the Assembly workbench, click Apply materials.
  4. Ensure the radio button for Current project is selected.
  5. Select Aluminum and click Apply to selected parts.
  6. Click Close.
  7. Press A to show all parts in the modeling window.
Create Rivets
  1. In the Connections workbench, click Virtual connectors > Rivets.
  2. In the Rivets dialog, select the Import rivets from .csv radio button.
  3. Click Import.
  4. Select the Rivets.csv file from File Explorer.
  5. Click OK.
Figure 7.
Create Structural Analysis
  1. In the main window toolbar, click Structural Analysis > Structural Linear.
  2. In the Analysis Workbench, click Immovable Support .
  3. In the dialog, verify the Faces radio button is selected.
  4. In the modeling window, select faces from all four sides of the skin.
    Figure 8.
  5. Click OK.
  6. In the Analysis Workbench, click Pressure > Uniform Pressure.
  7. Select the inner side face of the skin part and enter 0.5 MPa .
  8. Click OK.
Figure 9.
Edit Solution Settings
  1. In the Analysis branch of the Project Tree, double-click on Solution settings.
  2. In the Solution settings dialog, for Adaptation select Global+Local in the drop-down menu.
  3. Click OK.
Run Analysis
  1. In the Project Tree, open the Analysis Workbench.
  2. Click Solve
SimSolid runs the analyses in Design study 1. When finished, a Results branch for each analysis appears in the Project Tree.
Review Results
  1. In the , select Structural 1 subcase.
  2. In the Analysis Workbench toolbar, click Results plot.
  3. Select Displacement Magnitude.
    The Legend window opens and displays the contour plot.
