2025
Discover PollEx functionality with comprehensive user guides.
This section contains the user guides for the following tools: PI, SI, SI Explorer, and Thermal.
View new features for PollEx 2025.
Discover PollEx functionality with interactive tutorials.
This section contains the user guides for the following tools: Block JIG Generator, Compare GDSII, Gerber to PCB, Make Board Paneling, Metal Mask Manager, Mounting Data Extractor, Mounting Emulator, Router-Machine JIG Generator, Solder Quantity Calculator, Soldering Pallet, Test Point Location Generator, and Underfill.
This section contains the user guides for the following tools: BOM, CAM, Component Arrangement Plan, CP, Golden Sample, Logic, PCB, Redmark+, and Worksheet Planner.
Signal integrity (SI) is a measure of the quality of an electrical signal.
PollEx PCB has interfaces to many third-party layout tools, this capability allows you to import PCB design data produced by other third-party layout tools.
This tool is based on a design project database containing entire data of a PCB design including the materials, parts, physical layout, analysis models, and analysis result data. With the use of the unified design project database, this application can be commonly used by multiple engineering disciplines.
Classify nets according to their electrical characteristics.
Net properties are basic attributes influencing the electrical analysis.
Generate Net Group or Bus Group for use with PollEx DFE+.
View editable, versatile control parameters which influence the simulation/analysis results for crosstalk, network, electromagnetic field, eye-diagram, and SPICE.
Learn how to do versatile SI Analysis for the PCB system in Pre-route or Post-route stages.
This section contains the user guides for the following tools: DFA, DFE, DFE+, DFM, and Logic DFE.
This section contains the PollEx UPE user guide.
Instruction to install PollEx 2025.
Definition for meta character using in making sentence for searching option.
