2025
Discover PollEx functionality with comprehensive user guides.
This section contains the user guides for the following tools: DFA, DFE, DFE+, DFM, and Logic DFE.
View new features for PollEx 2025.
Discover PollEx functionality with interactive tutorials.
This section contains the user guides for the following tools: Block JIG Generator, Compare GDSII, Gerber to PCB, Make Board Paneling, Metal Mask Manager, Mounting Data Extractor, Mounting Emulator, Router-Machine JIG Generator, Solder Quantity Calculator, Soldering Pallet, Test Point Location Generator, and Underfill.
This section contains the user guides for the following tools: BOM, CAM, Component Arrangement Plan, CP, Golden Sample, Logic, PCB, Redmark+, and Worksheet Planner.
This section contains the user guides for the following tools: PI, SI, SI Explorer, and Thermal.
PollEx DFA is an assembly status checking toolset for PCB design based on 3D package library.
Group the same type of objects into the same group.
View DFE Environment setting methods.
Confirm the results when the selected test is completed.
Create a user defined excel format.
Create a user defined excel format for statistics.
PollEx DFE+ is a fully automated SI analysis tool.
PollEx DFM is a board level manufacturability checking software.
PollEx Logic DFE is a toolset that checks electrical validity and standardizing of schematic design.
PollEx Technical Cleanliness (TC) is an optional module of the PollEx PCB and a reliability analysis tool set for hazardous areas on a PCB design, using its micro particles.
This section contains the PollEx UPE user guide.
Instruction to install PollEx 2025.
Definition for meta character using in making sentence for searching option.
