2025
Discover PollEx functionality with comprehensive user guides.
This section contains the user guides for the following tools: DFA, DFE, DFE+, DFM, and Logic DFE.
PollEx Logic DFE is a toolset that checks electrical validity and standardizing of schematic design.
View new features for PollEx 2025.
Discover PollEx functionality with interactive tutorials.
This section contains the user guides for the following tools: Block JIG Generator, Compare GDSII, Gerber to PCB, Make Board Paneling, Metal Mask Manager, Mounting Data Extractor, Mounting Emulator, Router-Machine JIG Generator, Solder Quantity Calculator, Soldering Pallet, Test Point Location Generator, and Underfill.
This section contains the user guides for the following tools: BOM, CAM, Component Arrangement Plan, CP, Golden Sample, Logic, PCB, Redmark+, and Worksheet Planner.
This section contains the user guides for the following tools: PI, SI, SI Explorer, and Thermal.
PollEx DFA is an assembly status checking toolset for PCB design based on 3D package library.
PollEx DFE+ is a fully automated SI analysis tool.
PollEx DFM is a board level manufacturability checking software.
In this section, DFE rule input methods are explained.
Group similar target objects in the Classification section of the DFE Input dialog.
Manage and define DFE rule checks.
Create an excel format and export.
DFE input rule file (*.SDFEI) can be locked to prevent any modifications from users.
*.SDFEI
PollEx Technical Cleanliness (TC) is an optional module of the PollEx PCB and a reliability analysis tool set for hazardous areas on a PCB design, using its micro particles.
This section contains the PollEx UPE user guide.
Instruction to install PollEx 2025.
Definition for meta character using in making sentence for searching option.
