2025
Run a casting analysis to minimize defects and prevent manufacturing problems.
Discover new features and enhancements.
New to Inspire Cast? Learn the basics here.
Learn to use Inspire Cast with our interactive tutorials.
Create 2D sketches, surfaces, and solids with construction history and variables.
Designate and analyze casting parts, set gravity direction and mold opening direction, define runner system, and configure casting components.
Run a fast thermal analysis of the part.
Define the parameters for a basic, gravity, high pressure, or low pressure casting process.
Choose whether to run jobs in sequence or in parallel.
Define and run a filling analysis, solidification analysis, deformation analysis, trimming analysis, or a combination.
View the status of the current run, as well runs for the current model that have not yet been viewed. To see all past runs, you need to view the run history.
View, sort, open, and delete past runs for the current and previous models.
Review the results of a casting analysis.
Use the Animation Toolbar that appears at the bottom of the modeling window to animate and record results.
Download the Casting Benchmark Manual to learn more about benchmark and verification tests.
Got questions? We have answers!
