Statements
A statement is a complete instruction to the OpenMatrix language. Statements typically combine keywords and expressions.
A=sin(1+1)sin(1+1) is an expression.
1+1 is also an expression.A=sin(1+1) is a statement. if (a==0)
b=0
else
b=1
end is considered to be a single
statement, even though b=0 and b=1 are also statements.Statement Output
Each statement produces at least one output. If the statement is an assignment to a variable (or an element of a variable), then the output will be of the form:
variable = value
If the statement is NOT an assignment to a variable, then the output of the statement is automatically assigned to a special variable called 'ans.' The variable 'ans' can thereafter be used just like any other variable. The output will be of the form:
ans = value.
In order to suppress the output from a statement, a ; can be appended to the end of the statement. No output is displayed, but the 'ans' variable is assigned as it normally would.
a=4 a=4
1+1 ans=2
a=[4,0;0,2]
a(2,2) ans=2
1+1; <empty>
