- The Preprocessor PREFEKO
Use PREFEKO to perform meshing and to prepare the input files for the Feko solver.
- Running PREFEKO
Use PREFEKO with the correct syntax and optional parameters for advanced control.
- The Solver
The Solver is the electromagnetic solver component that calculates the specified output requests.
- OPTFEKO
OPTFEKO is the component that controls the optimisation process. The optimisation parameters are usually associated with geometric dimensions, material properties, excitations and loadings. For example, the gain of a horn antenna is maximised by varying the size of the horn aperture.
- ADAPTFEKO
ADAPTFEKO is the adaptive frequency utility used to automatically select smaller frequency steps near narrow resonances and larger steps where the results are relatively smooth.
- AMRFEKO
AMRFEKO is the adaptive mesh refinement utility used to automatically refine the mesh.
- Environment Initialisation Script - initfeko
The initfeko.bat (batch file on Windows) and initfeko (bash shell script on Unix / Linux) scripts are executed from a terminal to configure the Feko environment. From this environment, the Feko applications can be launched without using their full path.
- Launcher Utility
The Launcher utility is a single application that allows you quick access to the shortcuts for the Feko components, WinProp components (Microsoft Windows only), newFASANT, WRAP components (Microsoft Windows only), documentation and Altair license utility. Pin the application to the taskbar for quick launching.
- Updater
The feko_update_gui utility and the feko_update utility allows you the flexibility to install an update containing features, minor software enhancements and bug fixes on top of an existing base installation for Altair Feko (which includes Feko and WinProp).
- The Multiport Processor
The multiport processor allows you to calculate results for changes in the port excitations and loading without rerunning the Solver.
- S-Parameter Port De-embedding Calculator
The command line utility accepts an augmented S-parameter network definition, de-embeds the specified ports using 2-port calibration definitions and exports the result to an S-parameter Touchstone file.
- Crash Report Utility
In the event of a crash occurring in CADFEKO, POSTFEKO or EDITFEKO, the crash report utility generates a crash report.
- QUEUEFEKO
QUEUEFEKO is a graphical user interface (GUI) application that can create a package which you can transport to a remote queuing system. Created packages can be extracted once the simulation on the queuing system has been completed.
