Create Geometry - Line
You can use Flow Simulator to create lines, but this feature is not frequently needed for model creation. Geometry is usually created in a CAD program and loaded into Flow Simulator to aid in model creation and visualization.
- From the Geometry window, select to display the Create Line dialog:
- Enter the X, Y, Z values or select an existing vertex to specify the endpoints of the line.
- After the second endpoint is selected, click Create to create the line.
