Flux in SimLab : 2D and Skew Examples
2D Examples
| Solution | Example | Description | Illustration |
| 2D Transient Magnetic |
Brushless IPM motor | The studied device, a brushless AC embedded permanent magnet
motor presented in the figure in the right, includes the
following elements:
Brushless SPM motor |
The studied device, a brushless DC motor with surface permanent magnet, includes the following elements:
Multi-physics (EM, NVH, CFD) Analysis of a 75 kW PMSM - Motor Mode |
The studied device, a 75-kW permanent magnet synchronous
machine, is running in motor mode. As presented in the figure in
the right, it includes the following elements:
EM-CFD Coupling Analysis of a 75 kW PMSM (Air Cooling) - Generator Mode |
machine, is running in generator mode. As presented in the
figure in the right, it includes the following elements:
| 2D Transient Magnetic | Synchronous Reluctance Motor (SynRM) | The studied device, a synchronous reluctance motor, is
running in motor mode. As presented in the figure in the right,
| 2D Transient Magnetic | Wound Field Rotor Motor | The studied device, a wound field synchronous motor, is
running in motor mode. As presented in the figure below, it
| 2D Axi Transient Magnetic | Actuator | The studied device includes the following elements:
Skew Examples
| SKEW Transient Magnetic | PMSM with a step-skewed rotor |
The studied device, a permanent magnet synchronous motor (PMSM) presented in the figure in the right, includes the following elements:
| SKEW Transient Magnetic | PMSM with a continuous-skewed stator |
