What we can simulate with Flux
Introduction
Considering previous statements, what can we simulate with Flux, and how is the simulation carried out?
Heat transfer in Flux
Concerning the heat transfer types:
- only thermal conduction and radiation can be modeled in Flux
- thermal convection, which presupposes heat transfer to a fluid cannot be directly modeled in Flux. Thermal convection heat transfer characterizes the boundaries of solid regions of the studied device and the surrounding fluid. It is also the case for the radiation to infinite.
Thermal states and applications in Flux
With the Flux software, different thermal states correspond to different physical applications.
The two available physical applications are the Steady state Thermal and Transient Thermal applications. Features of these applications are listed in the table below.
| The state | is treated with the application… |
The power of thermal sources is… |
| steady | Steady state Thermal | constant in time |
| transient | Transient Thermal | constant in time |
| variable | Transient Thermal | time dependent |
Note: The Transient Thermal application of Flux enables the study of
both the transient and variable states.
