Compatibility of components according to the application
Compatibility component/application
The table below presents the compatibilities between components and the applications implemented with the Flux software:
| Component | Magneto static | Steady Stat AC Magnetic | Magnetic transient | Magneto thermal | |||||
| Flux2D | Flux3D | Flux2D | Flux3D | Flux2D | Flux3D | Flux2D | Flux3D | ||
| Resistor | X | X | X | X | X | X | |||
| Inductance | X | X | X | X | X | X | |||
| Capacitor | X | X | X | X | X | X | |||
| Source of voltage | Sinusoidal voltage source | X | X | X | X | ||||
| Voltage source to be defined | X | X | |||||||
| Source of current | Sinusoidal current source | X | X | X | X | ||||
| Current source to be defined | X | X | |||||||
| Coil conductor current | X | X | X | X | X | X | X | X | |
| Coil conductor circuit | X | X | X | X | X | X | |||
| Solid conductor 2 terminals | X | X | X | X | X | X | |||
| Solid conductor N terminals | X | X | X | ||||||
| Switch ron roff | X | X | |||||||
| Diode | Diode_uc_i_ron_roff | X | X | ||||||
| Diode_uc_i_exp_vf0_rb | X | X | |||||||
| Diode_uc_i_exponential | X | X | |||||||
| Brush-segment | X | X | |||||||
| Squirrel-cage | X | X | X | X | X | X | |||
| Ground | X | X | X | X | X | X | |||
