Extrude points
Before starting
It is necessary to have a transformation (created beforehand) and points to be able to extrude points.
Extrude points
To extrude points:
| Step | Action |
| 1 |
Select the points to extrude:
| 2 |
Activate the command *:
| → | A new dialogue box is opened. |
| 3 |
Fill out the fields:
| 4 |
Validate the information:
| → | The lines are created. |
| → | A new dialog box for the extrusion of entities of the same type is automatically opened. |
| 5 |
Quit the sequence:
Note: * You can also activate the extrusion command by clicking on Extrude
points in the menu (or on the icon
