Propagate faces / Propagate volumes
Before starting
It is necessary to have a transformation (created beforehand) and faces / volumes to be able to propagate faces / volumes.
Propagate faces / volumes
To propagate faces / volumes:
| Step | Action |
| 1 |
Select the faces / volumes to propagate:
| 2 |
Activate the command *:
| → | A new dialogue box is opened. |
| 3 |
Fill out the fields:
| 4 |
Validate the information:
| → | The new entities created (points, lines, faces, volumes) depend on the selected option. |
| → | A new dialog box for the extrusion of entities of the same type is automatically opened. |
| 5 |
Quit the sequence:
Note: * You can also activate the propagation command by clicking on
in the menu (or on the icon
