Automatic correction / simplification
Before starting
It is necessary to open the context for healing of CAD geometry as follows:
| Step | Action |
| 1 |
Pass to the healing mode via the menu Geometry and click on Context healing of CAD geometry |
| → | The healing mode for geometry is activated. |
Note: Click on
to go back.
Geometry automatic correction
To correct the geometry automatically, i.e. to correct all the blocking geometric defects:
| Step | Action |
| 1 |
Activate the command via the menu Healingand click on Heal geometry automatically |
| → | The geometric defects are corrected. |
Geometry automatic simplification
To simplify the geometry automatically, i.e. to fuse all the segments on the tangent of the straight line or all the arcs of circle having the same angle of curve:
| Step | Action |
| 1 |
Activate the command via the menu Healing and click on Simplify geometry automatically |
| → | The geometry is simplified. |
