Cut geometric objects
Cut a geometric object
To cut a geometric object:
| Step | Action |
| 1 |
Open the dialog box:
| → | The dialog box Select cut plane is opened. |
| 2 |
To cut one or several geometric objects:
| 3 |
Confirm: by clicking on |
Cutting sheets are created at the places where the objects can be cut. The dialog box Select cutting sheets is opened. |
| 4 |
To continue the cutting of the geometric object(s):
| 5 |
Confirm by clicking on OK |
| → | The new objects are created as a result of the cutting. |
