Exports to tabulated files
These exports enable the user to export the values of the data collection at the current step in a tabulated file. All the data collections are compatible.
No matter the export, the user should define:
- The type of value to be exported (to the nodes or to the elements)
- The data collection to export
- The name of the file to be exported
- The column separator (option)
- The column list of the file
Define the column list or a tabulated file
The column list can be defined via a definition box accessible by clicking on
List of tabulated columns:
- A new column can be added by clicking on the blank page
- The user can access the active column by clicking on the bin
- The user can switch from one column to another using the arrows
- Node or element ID
- Node or element barycenter coordinates
- Value at current step (complete value or specific component)
