Merge faces / Merge lines
Before starting
It is necessary to open the context for healing of facet geometry as follows:
| Step | Action |
| 1 |
Pass to the healing mode:
| → | The healing mode for geometry is activated. |
Note: Click on
to go back.
Merge faces
To merge faces after having imported a file with NASTRAN, PATRAN, IDEAS, or MED format:
| Step | Action |
| 1 |
Activate the command:
| → | A dialog box Merge … is opened. |
| 2 |
Useless for Merge all faces with Angle Select faces to merge:
| 3 |
Useless for Merge a list of faces Fill in the text zone:
| 4 |
Confirm:
| → | The faces are merged. |
| → | A dialog box Merge … is automatically opened. |
| 5 |
Exit the sequence:
Merge lines
To merge lines:
| Step | Action |
| 1 |
| 2 |
| 3 |
Confirm:
| → | The lines are merged. |
| 4 |
Exit the sequence:
