Import geometry
Import
To import geometry from XXX file:
| Step | Action |
| 1 |
Activate the command via the menu and click on Import geometry from XXX file |
| → | A dialog box Import geometry … is opened. |
| 2 |
Select a file:
| → | The complete path of the file is registered in the text zone XXX file to import of the dialog box Import geometry … . |
| 3 |
Choose the options for data conversion:
| 4 |
Confirm:
| → | A geometrical figure appears. |
