Mesh import: strategies
Strategies of mesh import
Previous to mesh data import is important to choose a strategy for the import. It is possible:
- to import a complete geometry of the device, i.e. all its components, the including box and the complete mesh of the study domain
- to import the geometry and the mesh of only one component or of a part of the device and to complete the description of geometry and mesh in Flux.
The further steps of the project depend on the chosen strategy.
Strategy 1
The first strategy consists in importing the whole study domain. The process of import can be presented as follows:
| Stage | Description |
| 1 |
Preparation of initial file in the origin software:
| 2 |
Data import into Flux by using the option:
| 3 |
Simplification of file:
| 4 | Direct passage to physics |
Strategy 2
The second strategy consists in importing a specific meshed part of the device. The process of import can be presented as follows:
| 1 |
Preparation of initial file in the origin software CAD (ex. rotor):
| 2 |
| 3 |
Simplification and adjustment of file:
| 4 |
Building in Flux of the rest of the device geometry (ex. stator):
| 5 | Direct passage to physics |
Constraints of Flux software
It is not possible to perform the following operations in an imported geometry containing lines of list edges type and faces of list facets type:
- modify the imported faces / lines
- propagate/extrude the imported faces / lines
- modify the mesh of imported objects; the initial mesh is entirely preserved
Capabilities of Flux software
It is possible to perform the following operations in an imported geometry:
- build the faces / volumes
- mesh the faces / volumes using automatic mesh generator
During the preparation of the initial file:
- you must verify that there is no non-conform mesh (ex: the addition of two parts separately meshed is forbidden)
- when the periodicity is present, you should perform an identical mesh on the faces concerning the periodicity
