Defeature holes / chamfers / fillets of objects
Introduction
The operation of Defeature holes / chamfers / fillets of an object allow to:
- Add matter in cylindrical holes whose diameters are smaller than a maximum diameter entered by the user
- Defeature Chamfer whose distances are smaller than a maximum distance entered by the user
- Defeature fillets whose radius are smaller than a maximum radius entered by the user
Structure of defeature objects
The operation Defeature holes / chamfers / fillets of an object is described by:
- The name of the operation geometric (by default DEFEATURE_1)
- The object to defeature
- To defeature fillets:
- The desired maximum radius below which detected fillets are defeatured
- The maximum angle between supports of fillets (by default: 175°)
- To defeature chamfers:
- The desired maximum length below which detected chamfers are defeatured
- The maximum angle between supports of chamfer (by default: 105°)
- To defeature holes (only cylindrical) :
- The desired maximum diameter below which detected holes are defeatured
- An option of detection of spheres
- (Optional) List of faces to keep during the defeaturing
Each type (fillet, chamfer, hole) has a button which allows unfolding parameters to define an to apply during the defeaturing
Examples
Here are some examples illustrated to show how the user values are taken into account.
| Dialog box | Before defeaturing | After defeaturing |
Result
The application of a defeaturing of objects has as result:
- A geometric operation DEFEATURE_1. This geometric operation is a specific entity of the modeler that permits to ensure the cycle of life of the construction (creation - modification - deletion).
- A defeatured object
- The operation DEFEATURE_1 has been added in the list of geometric operations linked with the defeatured object.
Possibilities for the user
The user have the following choice:
- The defeaturing of holes / chamfers / fillets of an object may be done in only one geometric operation
- or independently by achieving a defeaturing operation for each type to defeature
Access
The different accesses of the geometric operation Defeature hole / fillet / chamfer of an object are:
- By menu:
- Par
icon:
Creation of defeature an object
The process of creation of a Defeature an object is presented in the table below.
| Stage | Description |
| 1 | Opening the dialog box Defeature hole/chamfer/fillet |
| 2 | Choice of name of the resulting geometric operation (by default: DEFEATURE_1) |
| 3 | Choice of object to defeature |
| 4 |
Choice of parameters of defeaturing of fillets:
| 5 |
Choice of parameters of defeaturing of chamfers:
| 6 |
Choice of parameters of defeaturing of holes:
| 7 |
Choice of faces to keep:
| 8 | Validation by clicking on OK |
Limitations
Somes limitations :
- No preview available at the creation and at the modification
- Applicable only on one object: repeat the operation on each object to defeature
- No cylindrical holes are not detectable, so no defeaturing possible (section square, rectangular, oval…)
