Multiphysics session: opening and closing
Introduction
This paragraph describes the access commands to the multiphysics session:
- opening the multiphysics session
- closing the multiphysics session
Description of commands
The descriptions of the opening and closing commands of a multiphysics session are presented in the table below:
| Command | Description |
| Multiphysics solving session (existing scenario) * | Permits the opening of a multiphysics session starting from an existing scenario. |
| Close a multiphysics session | Permits the closing of a multiphysics session and to return to the standard environment of Flux. |
Note: * There is equally a command multiphysics solving process session (new scenario)
which permits the access to a multiphysics session by creating a void scenario on the
way (without a parameter). This command is available only for static applications
(impossible in transient applications).
Opening a multiphysics session
To open a multiphysics session:
| Step | Action |
| 1 |
Activate the session opening command:
| → | A dialog box « Multiphysics solving session (existing scenario) » is open |
| 2 | Choose the scenario * |
| 3 | Choose if the project must be saved under the current name or under another name. |
| 4 | Validate by OK |
| → | The multiphysics session is open. |
Note: * if there is no scenario, the user has the possibility to create it by clicking
on
Closing a multiphysics session
To close a multiphysics session:
- in the Project menu, click on Close a multiphysics
session (or click on icon
