Geometry dimensional checking: compute
Compute the distance between two points
To compute the distance between two points in a local coordinate system:
| Step | Action |
| 1 |
Activate the command:
| → | A dialog box Compute … is open. |
| 2 |
Fill out the fields:
| 3 |
Validate the information:
| → | The computation result appears in the output zone. |
| → | A dialog box Compute … is automatically opened. |
| 4 |
Quit the sequence:
Compute the coordinates of points
To compute the coordinates of points in the global coordinate system and in a local coordinate system:
| Step | Action |
| 1 |
| 2 |
| 3 |
| 4 |
Quit the sequence:
Compute lengths of lines / areas of faces
To compute lengths of lines / areas of faces:
| Step | Action |
| 1 |
| 2 |
| 3 |
| 4 |
Quit the sequence:
Compute a bounding box dimensions
To compute a bounding box:
| Step | Action |
| 1 |
The computation result appears in the output zone as follows:
