Final Rendering
Produce and save an image of your scene.
Define the Rendering Settings
Define the image resolution and select a rendering engine.
- On the ribbon, click the Rendering tab.
Click the Render tool.
The Rendering Options dialog box is displayed.
Edit the parameters:
Name Function Denoiser Reduce the amount of noise/grains in the final rendered image. There are noise/grains around the bottom of the car, as indicated by the red arrows. After applying a denoiser, noise/grains have been removed. Denoiser starting pass Define the number of passes after which the denoiser should start working. Tracing depth Define the maximum number of bounces a ray will have (diffuse, reflection, etc.).
Increase the value for a more accurate visualization, or decrease it to reduce rendering time.
Maximum samples Control the maximum number of times each pixel will be calculated and refined for further accuracy. Each additional sample smooths out noise/grain one step further. Use higher values for a smoother, cleaner rendering. Denoiser shared memory (AMD) Enables the denoiser to use shared memory in the GPU in order to share data with the application. This option improves performance because it avoids transferring data in CPU memory.
Create and Save a Rendering
Render the entire scene or selected objects in the scene to produce one image file. Once you've generated a final rendered image that you like, save it as a .jpg, .tiff, .png, or .bmp.
On the Rendering tab, select the
Render tool.
The Rendering Options window is displayed.
- If you haven't already, define the rendering settings. For more information, see Define the Rendering Settings.
Render the entire scene or selected objects.
To Do this Render the current view - Press Ctrl+R.
- On the Rendering tab, click the Render tool. In the Render Options window, click the Render button.
Render selected objects - Select the objects you'd like to render.
- Press I to isolate the selected objects. Isolating an object zooms in and temporarily hides all other objects.
- Press I again to un-isolate the selected objects.
The Rendering window is displayed. The progress is displayed at the bottom left. To start, pause, or resume rendering, click Start/Pause/Resume rendering
at the top right.
Once you've generated a final rendered image that you like, you can save it by
doing the following:
