TIME_HISTORY_OUTPUT
Specify nodal solution output for a set of prescribed points.
AcuSolve Command
TIME_HISTORY_OUTPUT("name") {parameters...}
Qualifier
User-given name.
- type (enumerated) [=nodal]
- How the spatial location of the output points is specified.
- nodal
- Nodal points. Requires nodes.
- coordinates
- Coordinate points. Requires coordinates.
- nodes (array) [no default]
- List of nodes to be output. Used with nodal type.
- coordinates or coord (array) [no default]
- Four-column array consisting of a point identifier (integer) plus the xyz coordinate points to be output. Used with coordinates type.
- output_frequency or out_freq (integer) >=0 [=1]
- Time step frequency at which to output nodal solutions. If zero, this option is ignored.
- output_time_interval or out_intv (integer) >=0 [=0]
- Time frequency at which to output nodal solutions. If zero, this option is ignored.
TIME_HISTORY_OUTPUT( "sample nodes" ) {
type = nodal
nodes = { 1 ;13 ;26 ; }
output_frequency = 10
output_time_interval = 2.5
}specifies that the nodal solution values of nodes 1, 13, and 26 are to be output every 10 time steps, every 2.5 units of time, and at the last time step.
The nodes parameter is a single-column array containing a list of node numbers. Node numbers must be valid numbers, as given by the COORDINATE command. The nodal solution of these nodes is output at the frequency specified.
1
13
26TIME_HISTORY_OUTPUT( "sample nodes" ) {
type = nodal
nodes = Read( "sample.nod" )
}TIME_HISTORY_OUTPUT( "sample coordinates" ) {
type = coordinates
coordinates = { 1, 1.1, 0.5, 7.8 ;
2, 1.5, 2.3, 4.6 ;
3, -3.2, 1.8, 5.4 ; }
}1 1.1 0.5 7.8
2 1.5 2.3 4.6
3 -3.2 1.8 5.4TIME_HISTORY_OUTPUT( "sample coordinates" ) {
type = coordinates
coordinates = Read( "sample.crd" )
}Any point in coordinates that falls outside of the mesh is projected to the nearest point in the mesh.
Once the output to disk is complete, it can then be translated to other formats using the AcuTrans program and other post-processing modules; see the AcuSolve Programs Reference Manual for details.
If either output_frequency or output_time_interval is non-zero, the solution points will be output at the end of the run. If both are zero, no data are output.
Run times may not coincide with output_time_interval. In this case, the solution points are output every time step which passes through a multiple of output_time_interval.
The TIME_HISTORY_OUTPUT command is designed for outputting a select number of points at higher frequency levels than is practical with the NODAL_OUTPUT command. However, if the number of points in TIME_HISTORY_OUTPUT becomes large, the use of TIME_HISTORY_OUTPUT can become less efficient than the use of the NODAL_OUTPUT command.
