udfGetElmNQuads()
Return the number of quadrature points of the quadrature rule for the element set.
nQuads = udfGetElmNQuadType( udfHd ) ;
User Defined Element
- udfHd
- The opaque handle (pointer) which was passed to the user function.
Return Value
- nQuads (integer)
- Number of quadrature points of the quadrature rule for the element set.
This routine returns the number of quadrature points of the quadrature rule for the element set.
For
example,
Integer nQuads ;
nQuads = udfGetElmNQuads( udfHd ) ;Errors
- This routine expects a valid udfHd.
- This routine may only be called within a Body Force, Material Model or Component Model user function.
