ACU-T: 3200 Radiation Heat Transfer in a Simple Headlamp using the Enclosure Radiation Model
Tutorial Level: Intermediate
Prerequisites
This tutorial introduces you to the workflow for setting up a thermal radiation problem in a headlamp using the enclosure radiation model in HyperMesh CFD. Prior to starting this tutorial, you should have already run through the introductory tutorial, ACU-T: 1000 UI Introduction, and have a basic understanding of HyperMesh CFD and AcuSolve. To run this simulation, you will need access to a licensed version of HyperMesh CFD and AcuSolve.
Problem Description
Start HyperMesh CFD and Create the HyperMesh Model Database
Start HyperMesh CFD from the Windows Start
menu by clicking .
When HyperMesh CFD is loaded, the Geometry ribbon is open by default.
Create a new .hm database in
one of the following ways:
- From the menu bar, click .
- From the Home tools, Files tool group, click the Save As tool.
Figure 3.
- In the Save File As dialog, navigate to the directory where you would like to save the database.
Enter Headlamp_Enclosure as the name for
the database then click Save.
This will be your problem directory and all the files related to the simulation will be stored in this location.
Import and Validate the Geometry
Import the Geometry
- In the Import File dialog, browse to your working directory then select ACU-T3200_headlamp.x_t and click Open.
In the Geometry Import Options dialog, leave all the
default options unchanged then click Import.
Figure 4.
Figure 5.
From the Geometry ribbon, click the Validate tool.
Figure 6.
The Validate tool scans through the entire model, performs checks on the surfaces and solids, and flags any defects in the geometry, such as free edges, closed shells, intersections, duplicates, and slivers.The surface and solid errors display in the list below the tool.Figure 7.
Click SolidChecks.
The Solid Repair tool opens, which you can use to fix the geometric errors in the model.From the SolidChecks legend, you can see the model's solids have five intersections.
Figure 8.
Click Intersections.
A guide bar used to fix intersecting solids displays.
- Optional:
Click
and
to review each
error.
Activate the Keep common interface option then click
Combine All.
The SolidChecks legend should now display zero for all errors.
Click the Validate tool
once again.
Observe that a blue check mark now appears on the top-left corner of the tool icon. This indicates that no issues are detected and you are ready to continue.
Figure 9.
Set Up Flow
Figure 10.
The Setup dialog opens. -
- Verify that Time marching is set to Steady.
- Select Laminar as the Turbulence model.
- Activate the Include gravitational acceleration checkbox and set the gravity in the y direction to -9.81.
- Activate the Heat transfer checkbox.
Figure 11.
Click the Solver controls setting and activate the
Thermal flow equation.
Figure 12.
- Close the dialog and save the model.
Define the Material Models
From the Flow ribbon, click the Material Library tool.
Figure 13.
The Material Library dialog opens. - Click the My Materials tab.
Click
to add a new fluid
material model.
- In the material creation dialog, click the name in the top-left corner and rename the material to Air_Boussinesq.
In the Density tab,
- Set the Type to Boussinesq.
- Set the Density value to 1.225.
- Set the Expansivity value to 0.00347222.
- Reference temperature value to 288.
Figure 14.
Click the Specific Heat tab and set the Specific heat
value to 1005.
Figure 15.
Click the Viscosity tab and set the Viscosity value to
1.781e-05.
Figure 16.
Click the Conductivity tab and set the Conductivity
value to 0.02521.
Figure 17.
- Close the material creation dialog to return to the Material Library dialog.
Select Solid in the Settings menu, click the
My Materials tab, then click
to create a new
solid material model.
Name the material Plastic and set the following
values.
The Type should be Constant for each property.
- Density: 1270
- Specific Heat: 1900
- Conductivity: 0.2
Similarly, create new solid material models named Arnite
and LED with the following properties.
The Type should be Constant for each property.Arnite:
- Density: 1670
- Specific Heat: 2050
- Conductivity: 1.6
LED:- Density: 5500
- Specific Heat: 0.3
- Conductivity: 5.0
Figure 18.
- Close all dialogs and save the model.
Assign Material Properties
Figure 19.
Click the lens volume highlighted in the figure below and select
Arnite from the Material drop-down menu.
Figure 20.
On the guide bar, click
to execute the command and remain in the
tool.
Click the housing volume and assign the Plastic material
model.
Figure 21.
tool.
- In the Materials legend, right-click on Air and select Isolate.
Click the air volume and assign the Air_Boussinesq
material model.
Figure 22.
tool.
Click the bulb volume and assign the LED material
model.
Figure 23.
to execute
- Save the model.
Define the Heat Source
From the Flow ribbon, click the tool.
Figure 24.
- In the modeling window, select the bulb volume.
In the Heat Source dialog, set the heat source value to
2049180 W/m3.
Figure 25.
to execute
- Press Esc to exit the Sources tool then press the A key to turn on the display of all solids.
- Save the model.
In this problem, all the surfaces are walls and will therefore be assigned the default wall boundary condition. The outer walls of the headlamp will be given a no-slip wall boundary condition with a convective heat flux boundary condition.
From the Flow ribbon, click the No Slip tool.
Figure 26.
In the modeling window, select the surfaces highlighted
in the figure below.
Figure 27.
In the microdialog, enter the values shown in the
figure below.
Figure 28.
- In the Boundaries legend, double-click Wall, rename it to Outerwalls, then press Enter.
to execute
- Save the model.
Set Up Radiation
In this step, you will specify the parameters related to the thermal radiation setup.
Define Radiation Model Settings
From the Radiation ribbon, Thermal Radiation tools, click the Physics tool.
Figure 29.
The Radiation Settings dialog opens. -
Activate Thermal radiation and set the Radiation model
to Enclosure (if not set already).
Figure 30.
- Close the dialog.
Define the Emissivity Models
From the Radiation ribbon, click the
Surface Finish Library
tool.
Figure 31.
The Surface finish library opens. -
Click
to add a
new emissivity model.
Set the Name of the model to Walls and the Emissivity
value to 0.7 by double-clicking on the entity
fields.
Figure 32.
- Close the dialog.
Assign Surface Finish Models
Surface Finish
tool.
Figure 33.
Using the window selection method, select all the surfaces in the model.
Figure 34.
- In the microdialog, assign the Walls emissivity model.
to execute
- Save the model.
Generate the Mesh
In this step, you will define the mesh controls and then generate the mesh.
Define the Surface Mesh Controls
From the Mesh ribbon, click the Surface tool.
Figure 35.
- Using the window selection method, select all the surfaces in the model.
In the microdialog, set the Average element size to
0.002.
Figure 36.
to execute
Define the Boundary Layer Controls
From the Mesh ribbon, click the Boundary Layer tool.
Figure 37.
Right-click in the modeling window and go to .
All the fluid wall surfaces should be selected and a microdialog for BL specification appears.
Enter the following values in the microdialog:
- First layer thickness definition: Constant
- First layer thickness: 0.0005
- Total number of layers: 4
- Growth method: Constant
- Initial growth rate: 1.3
- Termination policy: Truncate
- Activate the Enable surface mesh modification option
Figure 38.
to execute
Define the Volume Mesh Controls
Since the thickness of the housing and the lens solids are small, you will use the thin layer meshing tool so that when the volume mesh is generated, there will be two layers across the thickness of those solids.
From the Mesh ribbon, click the Volume Mesh tool.
Figure 39.
- Select the housing and the lens solids.
In the microdialog,
- Set the Average size to 0.001.
- Set the Growth rate to 1.0.
- Activate the Thin layer meshing option and set the Number of layers to 2.
Figure 40.
to execute
Generate the Mesh
Volume tool.
Figure 41.
The Meshing Operations dialog opens. - Set the Mesh growth rate to 1.
Click Mesh.
The Run Status dialog opens. Once the run is complete, the status is updated and you can close the dialog.Tip: Right-click on the mesh job and select View log file to view a summary of the meshing process.
- Save the model.
Run AcuSolve
Figure 42.
- Expand the Default initial conditions menu and deactivate the Pre-compute flow option.
- Set the x-velocity to 0 and the Temperature to 300.
Leave the remaining options as default and click
Run to launch AcuSolve.
Figure 43.
The Run Status dialog opens. Once the run is complete, the status is updated and you can close the dialog.Tip: While AcuSolve is running, right-click on the AcuSolve job in the Run Status dialog and select View Log File to monitor the solution process.
Post-Process the Results with HM-CFD Post
- Once the solution is completed, navigate to the Post ribbon.
Select the AcuSolve log file in your problem
directory to load the results for post-processing.
The solid and all the surfaces are loaded in the Post Browser.
Hide the Outerwalls boundary surface in the Post Browser.
Figure 44.
Select the inner surface of the lens in the modeling window, right-click, and select
Hide.
Figure 45.
Similarly, hide the outer fluid surface.
You should end up with a view as shown below.
Figure 46.
Click the Boundary Groups tool.
Figure 47.
Select all visible surfaces in the modeling window.
Rotate the model if needed to select the rear surfaces.
- In the display properties microdialog, set the display to temperature.
Activate the Legend toggle and click
to reset the range.
Click
, set the Legend location to Upper Right
Corner, and the Colormap Name to Rainbow
Uniform.
Figure 48.
Click
on the guide bar.
Click the Top face on the View Cube to align the
model.
Figure 49.
Figure 50.
Summary
In this tutorial, you learned how to set up and solve a radiation heat transfer problem in a headlamp using the enclosure radiation model in AcuSolve using HyperMesh CFD. You started by importing the headlamp geometry file, then you set up the simulation parameters and boundary conditions. Once the solution was computed, you processed the results using the Post ribbon where you created contour plots of temperature.
