AcuCleanDir
A command line tool called AcuCleanDir is also
available for managing the field output files in ACUSIM.DIR.
Using this tool, it is possible to delete selective output types, steps, or an
entire run.
Note: This tool does not operate on time series data, only nodal
data.
To use AcuCleanDir:
- Open an AcuSolve Cmd Prompt from the Windows Start menu by clicking .
- Change to the directory where your problem is saved.
Execute the acuCleanDir command with appropriate options.
- To delete run 2 of a problem named
"channel":
acuCleanDir -pb channel -run 2 -delrun - To delete all but the last time step of each result
type:
acuCleanDir -pb channel -run 2 -ts ablwhere abl is a string that means "all but last".
- To delete nodal output and nodal residual outputs from time steps
between the first and last
available:
acuCleanDir -pb channel -run 2 -ts F:L:2 -types out,onrwhere the options for -types are:out NODAL_OUTPUT odq DERIVED_QUANTITY_OUTPUT onr NODAL_RESIDUAL_OUTPUT ora RUNNING_AVERAGE_OUTPUT ota TIME_AVERAGE_OUTPUT rst RESTART_OUTPUT oee ERROR_ESTIMATOR_OUTPUT oae ERROR_ESTIMATOR_OUTPUT - time averaged A command line tool called acuCpProbeFiles can be used to summarize the results of a given AcuSolve simulation. Executing the script will copy the pertinent files from ACUSIM.DIR and the .log file into a directory specified by the command line argument –tdir (default is PROBE.DIR). The PROBE.DIR directory can be used by itself to interrogate results with AcuProbe.Note: Nodal output is not stored within PROBE.DIR.acuCpProbeFiles -pb channel -run 1 –tdir PROBE.DIR
"channel":
