ELIST
Bulk Data Entry Specifies damp shell elements for a fluid volume. ELIST entries are referenced by the MFLUID entry.
| ELIST | LID | EID1 | EID2 | EID3 | EID4 | EID5 | EID6 | EID7 | |
| EID8 | EID9 | EID10 | etc |
| ELIST | 25 | 47 | 22 | THRU | 35 | -56 | -57 |
| LID | List
of identification number. No default (Integer > 0) |
| EID | Element identification number of
CQUAD4,
CTRIA3,
CQUADR, and
CTRIAR elements that are damp
in the fluid volume. No default (Integer ≠ 0 or "THRU") |
- By default, for elements only damp on one side (see WSURF1 on MFLUID entry), the damp side of an element is on the same side of the element's normal. But a negative EIDi indicates that the fluid is opposite to the normal. If there are negative EIDi's specified in a "THRU" range, then both EIDi's in the range must be negative.
- Alternatively, the SURF and SET entries may be used to define damp elements but the SURF and SET entries may not be combined in the single with ELIST entries to define damp elements. For example, if any MFLUID references a missing ELIST,25, then the program will not search for a SET,25 if a ELIST card exists in the deck.
- ELIST is an
alternative to SET and
SURF, but
ELIST is intended only to provide
compatibility with Nastran
decks. It is recommended to use
SURF/SET
instead of ELIST. Additionally,
- The SURF and SET entries may not be combined with ELIST entries to define damp elements.
- ELIST entries are internally converted to SET entries. If ELIST is referenced on a minimum of one MFLUID entry, then all MFLUID entries in a model must reference ELIST entries. In such cases, if an MFLUID entry references a particular Set Identification Number (<SID>) to define WSURF1/WSURF2 fields without a corresponding ELIST,<SID> in the model, then OptiStruct will not search for a SET/SURF,<SID>.
- ELIST entries are internally converted to SET entries. The continuation is optional.
