Parts
Identify Part
Analysis > Parts > Identify Parts
When analyzing the vehicle, the components are divided into the sub-assemblies: Body, Front wheel and Rear wheel.
Figure 1. Identify Part in SimLab
A sub-assembly is created for the selected components, to which the corresponding material is automatically assigned in the background.
The front and rear wheels should be separate components. The wheel can either be a single component or a combination of tire and rim.
Auto Vehicle Position
Analysis > Parts > Auto Vehicle Position
Using the Auto Vehicle Position tool, the vehicle is positioned in the desired orientation relative to the channel based on the coordinates of the channel and the dimensions of the front and rear wheels.
