Run Altair HyperWorks Products on Windows
The installation process creates an Altair group on the Start menu for Windows 10/11.
The default name of the group can be changed during installation. Most applications can be started using the following instructions.
Run an Altair HyperWorks Product
- From the Start menu on Windows 10/11, click Altair 2025, or the name defined during the installation.
- Select the name of the program you want to run.
Run an Altair HyperWorks Product through ConnectMe
ConnectMe provides you with an alternative way to manage and launch installed Altair HyperWorks products, receive notifications of new product updates, download Altair HyperWorks products, and get access to most recent Altair news.
ConnectMe is installed by default with Altair HyperWorks Desktop and Solvers packages.
Open ConnectMe.
Option Description If ConnectMe was launched at startup From the system tray, click
.Launch ConnectMe at startup by selecting the Launch ConnectMe at Startup checkbox located in the ConnectMe settings.
If ConnectMe is not already running From the Start menu, select All Programs or the All Apps menu (Windows 10) and click . -
From the Start tab, invoke a product by clicking one of
the following:
The Start tab provides direct shortcuts to invoke all of the Altair HyperWorks products.
- Product icon
- Product name
- Open button
Change the Default Working Directory on Windows
For Windows 10/11, the default working directory specified by an Altair HyperWorks application is %USERPROFILE%\Documents.
Go to:
- For Windows 10/11, click .
Right-click the Altair HyperWorks
application for which you want to set the working directory.
On Windows 10/11 select Open file location then right-click on the shortcut of the Altair HyperWorks application you want to change.
- From the menu, select Properties.
- Select the Shortcut tab.
- In the Start in text box, enter the explicit path name of the folder from which you want to run the Altair HyperWorks application.
Click OK.
Your user files are created in the directory specified in Step 5. For example, if you had selected HyperMesh, command<#>.tcl, and hmmenu.set would go to this directory.
Applications That Run in Batch Mode
The following table provides some examples of batch applications and their input file requirements. The details of how to run an application in batch mode can be found in the help of individual applications.
| Application | Script Name | Required Input File |
| Radioss 1 Step | hfsol.bat | Use base name of .parm file |
| HyperMesh batch | hmbatch.exe | -cfilename.cmf or -tcl <tcl_filename> |
| HyperStudy | hstbatch.exe | <filename>.xml |
| MotionSolve | motionsolve.bat | filename.xml or filename.acf (ADAMS command file) |
| OptiStruct | optistruct.bat | File in Bulk format (.fem file) |
| BatchMesher | hw-batchmesh | CAD input file |
| Radioss | radioss.bat | File in Block or Engine format (.rad) |
Launch a Batch Application
HyperWorks/Client Cache Management
The HyperWorks server/client cache management system allows for GUI applications, such as HyperMesh, to cache files onto a client’s machine for faster invoke times.
The cache is versioned and the client user should maintain the necessary files for new and old versions.
The cache is supported only for Windows server/client setups. The default behavior of a server/client HyperWorks setup does not cache any files.
On first invoke, the applications will check to see if the environment variable ALTAIR_CACHE_HOME is set. If so, the application will copy over all required files to the specified directory through a background process after the products initialize. There will not be any increase in invoke speed this first time. Once this is completed, subsequent invokes will use the variable to check and find the versioned files and use the files stored locally to the client instead of reading the files over the network.
hw_cachemgr.exe -option ?-silent?.- -option
- -query
- Display a message if the cache is ready for use. Always returns zero.
- -create
- Create the cache if it is not being deleted. Returns zero if successful.
- -delete
- Delete the cache if it is not being used. Returns zero if successful.
- -silent
- Do not display messages.
- The client user is responsible for adding the ALTAIR_CACHE_HOME environment variable to enable this functionality.
- The client user must have write access to the ALTAIR_CACHE_HOME directory.
- The client user must have enough disk space available for the cache, which is approximately 120 MB to 150 MB of storage.
- The client user is responsible for deleting the cached files when no longer needed.
Logging of cache messages can also be enabled via the ALTAIR_CACHE_LOG environment variable.
