Altair HyperGraph 2025 Release Notes
General
New Features
- Added Single Vector Macros to the Stackmath Workflow
- The stackmath user interface has been replaced with the Math Macro dialog to allow for additional coverage.
- Tip to Tail Tool
- The Tip to Tail tool has been migrated from a panel to a dialog. From the Vector Chart ribbon, select the Tip to Tail tool.
Enhancements
- Reader Enhancements
- Support for the .CUR format for OASIS T/HIS software.
Resolved Issues
- XY data import.
- 3D zoom and pan.
- Nte calculation issue has been resolved for crash use cases.
- Secondary axis scaling when units are activated.
Extensions
Enhancements
- Improved Version Administration
- When multiple extensions with the same name and author but different
versions and minimum product versions are registered, the extension with
the most fitting
"minProductVersion"and with the highest"version"will be loaded first.Figure 1.
- Improved Messaging
- Improved messaging when an extension fails to register. More information
about other registered extensions with the same name and author are now
provided.
- $EXTENSION_DIR Variable Support
- The
$EXTENSION_DIRvariable is now supported for all command attributes in the XML files. The previously limitation that the$EXTENSION_DIRvariable was supported only for the command attribute no longer applies, all command type attributes are now supported.Figure 3.
