ACSRCE
Bulk Data Entry Defines acoustic source as a function of power versus frequency.
| ACSRCE | SID | EXCITEID | DELAY | DPHASE | TP | RHO | B |
| ACSRCE | 111 | 29 | -0.2 | 87 | 14 | 1.0 | 15 |
| SID | Dynamic load set
| EXCITEID | Identification number of
an SLOAD entry set that
defines
| DELAY | Defines time delay
. If it is a non-zero integer, it represents
the identification number of a DELAY Bulk Data Entry that
defines
. If it is real, it directly defines the
value of
that will be used for all
degrees-of-freedom that are excited by this dynamic load
entry. Default = 0 (Integer > 0, or Real) |
| DPHASE | Defines phase
represents the identification number of a DPHASE Bulk Data Entry that
defines
value of
| TP | Set identification number
of the TABLED1, TABLED2, TABLED3, or TABLED4 entry that gives
. Default = 0 (Integer > 0) |
| RHO | Fluid density. No default (Real > 0.0) |
| B | Bulk modulus of
fluid. No default (Real > 0.0) |
- The source strength is calculated
as:where,
- Dynamic load sets must be selected in the I/O Options or Subcase Information sections with the command DLOAD = SID.
- SID must be unique with respect to other dynamic load sets, ACSRCE, DLOAD, RLOAD1, RLOAD2, TLOAD1, and TLOAD2 entries.
- The referenced EXCITEID, DELAY and DPHASE entries must specify fluid points only.
- If either DELAY or DPHASE are blank or zero, the corresponding or will be zero.
- A (defined in EXCITEID) is a dimensionless quantity and the units of (defined in TP) is of Power (kg*m2/s3, N*m/s, or J/s).
