DLOAD
Bulk Data Entry Defines a dynamic loading condition for frequency response problems as a linear combination of load sets defined via RLOAD1 and RLOAD2 entries, or for transient problems as a linear combination of load sets defined via TLOAD1 and TLOAD2 entries, or acoustic source ACSRCE entries.
Attention: Valid for Implicit
and Explicit Analysis
| DLOAD | SID | S | S1 | L1 | S2 | L2 | S3 | L3 | |
| S4 | L4 | etc | etc | etc | etc | etc | etc |
| DLOAD | 5 | 1.0 | 2.0 | 101 | 2.0 | 102 | 2.0 | 103 | |
| -2.0 | 201 |
- Dynamic load sets must be selected in the I/O Options or Subcase Information sections with DLOAD=SID. (DLOAD I/O Options and Subcase Information Entry).
- The load vector being defined by this entry
is given by:
- Each L# must be unique from any other L# on the same entry.
- SID must be unique from all RLOAD1 and RLOAD2 or TLOAD1 and TLOAD2 entries.
- A DLOAD entry may not reference a set identification number defined by another DLOAD entry.
- RLOAD1 and RLOAD2 loads and TLOAD1 and TLOAD2 loads may be combined only through the use of the DLOAD entry.
- This card is represented as a load collector in HyperMesh.
