INLTVEL
Subcase Information Entry Used to select an inlet flow velocity boundary condition.
INLTVEL = option
| Argument | Option | Description |
| option | <SID> No default |
- Only one INLTVEL entry can be present for each subcase. An SPCP Bulk/Subcase Entry pair is mandatory to activate flow analysis in steady-state heat transfer analysis. The INLTVEL Bulk/Subcase pair is optional.
- Darcy Flow Analysis is currently only supported for Steady-State Heat Transfer.
- For inlet flow conditions, there
are two options:
- Use SPCP Bulk Data to define both inlet and outlet flow pressures, leading to a definition of flow pressure differential.
- Use SPCP Bulk Data to define outlet pressure and use the INLTVEL Bulk/Subcase pair to define the inlet velocity.
