RADSND
Bulk Data Entry Defines a set of grid points where the sound will be calculated as well as the panels that are generating the sound.
| RADSND | RSID | MSET | |||||||
| "PANEL" | PID | PID | PID | etc. |
| RADSND | 10 | 100 | |||||||
| PANEL | 101 | 103 |
| RSID | Radiated sound set
| MSET | ID of a
SET of field grids (microphone locations) at
which sound levels will be calculated. The sound levels output at
these grid points are due to panel vibrations (specified separately
in the PANEL and PIDi fields.
4 No default (Integer > 0) |
| PANEL | Flag indicating that the
following panel ID's will contribute to the sound at the
MSET grids. 4 No default (Character) |
| PIDi | Panel identification
number of the PANELG Data
Entry of type "SOUND" data. No default (Integer > 0) |
- At least the first panel ID is required.
- Multiple continuations or multiple RADSND with the same SID are allowed if more than 7 SOUND panels need to be defined.
- The RADSND Bulk Data Entry is referenced by the RADSND command in the Subcase Information section of the input data.
- The MSET and
PIDi fields are used to specify the microphone locations
(receiving grids) and the vibrating panels (source grids), respectively.
- RADSND Data Entry Field
- Description
- MSET
- References microphone grid sets (receiving grids)
- PANEL, PIDi
- Reference vibrating panel ID's (source grids)
