RADSND
Subcase Information Entry The RADSND command can be used to select RADSND Bulk Data to specify sound generation panels and microphone field locations.
RADSND = option
| Argument | Options | Description |
| option | <SID> Integer > 0 No default |
- Only one RADSND entry can be present in any particular subcase.
- If a RADSND entry is present above the first subcase, then it is applied as the default for each applicable subcase.
