2025
View new features for HyperLife 2025.
Discover HyperLife functionality with interactive tutorials.
Fatigue Analysis is intended for solutions to structures in a large number of loading cycles.
Set up your model for analysis.
Run the model and view results.
File formats supported.
The following file types are generated by HyperLife.
Create a new file.
Open a file.
Save all of the data in your current session.
Export the current contour result file.
Take a screen capture of your model and save it to your working directory.
Explore additional post-processing options related to the input result files.
Explore verification problems for SN and EN with time series loading.
