2025
Translate, rotate, and align the model.
View new features for HyperLife Weld Certification 2025.
Learn the features and benefits of HyperLife Weld Certification.
Discover the software compatible with HyperLife Weld Certification.
Discover the files required to work with HyperLife Weld Certification.
Explore the user interface.
View controls enable you to control the view and display of your model in the modeling window.
Select and deselect entities to modify with other tools. Selected entities are outlined to indicate their selection state.
Use snap points to help align geometry.
Reposition the Move tool to align a manipulator along an axis, along a vector, along a plane normal, within a plane, or in 3D space to change the center of rotation.
Prevent components from passing through other components.
Position entities by specifying source and target locations.
Use the Measure tool to draw, length, angle, and radius measurements in the modeling window.
Undo and redo actions.
Default keyboard shortcuts and mouse controls.
Discover HyperLife Weld Certification functionality with interactive tutorials.
Set up the model for weld evaluation.
Learn details about the core modules used in HL-WC calculations along with the parameters that are assigned based on the standards.
Learn how to manipulate entities.
