Define Gradients
Gradients calculate the change of the output responses with respect to the input variables. The gradient information can be used in gradient enabled methods inside of a DOE, Fit, Optimization, or Stochastic approaches.
Gradients may also be defined using a combination of results read or extracted from a file and input variable values. These equations may use the functions available or external functions, including Compose/OML and Python functions. HyperStudy uses HyperWorks readers, and hence can read the binary output files of most popular CAE solvers. Additional data can be read using custom external readers and import templates. External readers, external functions and import templates may be manually added in the preference file or registered through the Edit menu.
- In the Define Output Responses step, click the Gradients tab.
Click Add Gradient.
A new gradient is created and added to the work area.
- In the Label column, enter a name for the gradient.
- In the Derivative of column, enter the varname of the output response to be associated with this gradient.
- In the Respect to column, enter the varname of the input variable to be associated with this gradient.
Define the output response expression.
- Manually enter the expression in the Expression column.
- Build an expression using the Expression Builder, which can be accessed
by clicking
in the Expression
column.
- Click Evaluate to extract the gradient value.
