- ::AddToolbarIconThis command will create a new toolbar and add an icon to the toolbar.
- ::DrawActiveWindowThis command is used to draw the active window in the active page. There is an option     to “fit” all of the model contents within the graphic area.
- ::EscapeCharacterInstances
- ::EscapeEmbededQuotesIfLiteralThis command will insert a “\” character before every instance of a specified character     in a specified string.
- ::GetAggregateCGAndInertiaThis command will return the aggregate Mass, CG, Moment of Inertia, or Product of     Inertia based on the inputs specified. On successful execution of the command, it will return     the aggregate value or values. The moment of inertia and product of inertia values returned are     with respect to a coordinate system parallel to Global Frame at the aggregate CG of the bodies     provided in the list argList.
- ::GetClientHandleThis command will get a handle for the MotionView client in     the active page and the active window.
- ::GetCurrentLRTabThis command gets the current “side” tab that is selected when the current panel is for     a pair entity. This command only gets the current “Left” or “Right” values for the “side” tab if     the panel is a Tcl/Tk panel. It returns “L” when the “Left” side is selected and “R” when it is     the “Right” side. If the current panel is for a single entity, the last selected “side” tab is     returned.
- ::GetMangleThis command will return a single string that starts with an underscore (“_”), then a     unique numeric value, then another underscore followed by the string specified for the       “argInfo” argument. This function is commonly used to get a unique name     that can be used for a handle name.
- ::GetNamespaceListThis command is used retrieve all the public namespaces which are exposed to the users     as a list.
- ::GetNextAvailableVarnameAndLabelThis command will be used to get the next available (not already used) pair of varname     and label values for a given base name and base label within a given system.
- ::GetPanelSelectionThis command returns the full varname of the last selected entity for the specified Tcl     panel. If there had not yet been a selection for the specified panel, if there had been a pick     for the System panel, that is returned, otherwise an empty string is returned.
- ::GetProcedureListThis command is used retrieve all the public exposed methods for a given namespace as a     list.
- ::GetValidLocationToAddItemFrom the current selected item(s) in the browser, this command will return the deepest     valid (full variable name) container (Assembly/System/Analysis/Template, etc.) for adding an     instance of the specified registered entity type.
- ::IsSystemTypedThis command will be used to determine whether a particular system or analysis or     assembly is typed or not. In order for a container to be typed, the user must have specified     either a type after the TYPED keyword in the MDL definition or specified a type in the     container’s “Properties” tab in the GUI.
- ::IsValidVarnameThis command will check all of the characters of the specified variable name to ensure     that they are all valid for a MotionView varname. This is a generic     test only and does not ensure that the variable name is valid within a particular context.     Variable names in MotionView must start with a letter and can     contain only letters, numbers and the underscore character.
- ::ListNamespacesThis command is used to retrieve all the public namespaces which are exposed to the     users. Each namespace will be displayed in a new line.
- ::ListProceduresThis command is used retrieve all the public exposed methods for a given namespace.     Each method will be displayed in a new line.
- ::mdl3StateEntryThis command creates an mdl3StateEntry widget that is tied to a     numerical data member of an existing entity in the model. The mdl3StateEntry     widget can accept a scalar numerical value or an equation. When an equation is entered, the     equation is stored in the data member as a raw value and the evaluated results are displayed.     The entry turns blue to indicate it is an evaluated value.
- ::mdlArrayThis command creates a CheckBox widget that is tied to a data member of an existing     entity in the model.
- ::mdlAttachmentTableThis command creates a table widget for the attachments. This table allows the user to     edit and/or resolve the attachments that it contains. The table supports either a system (all of     the attachments for that system) or a list of attachments.
- ::mdlCheckBoxThis command creates a CheckBox widget that is tied to a data member of an existing     entity in the model.
- ::mdlCollectorThis command creates a mdlCollector widget that is tied to a     Reference data member of an existing entity in the model.
- ::mdlComboBoxThis command creates an mdlComboBox widget that is tied to a list     variable.
- ::mdlComboBoxDMThis command creates an mdlComboBoxDM widget that is tied to a data     member of an existing entity in the model.
- ::mdlFileNameThis command creates an mdlFileName widget that is tied to a     FileName data member of an existing entity in the model.
- ::mdlFormThis command will be used to create a form widget and this will be attached to the form     entity passed as an argument. This mdlForm widget is a “table”-like widget     with its contents completely defined by the form entity defined in the MDL.
- ::mdlIntDMComboBoxThis command will be used to create a form widget and this will be attached to the form     entity passed as an argument. This mdlForm widget is a “table”-like widget     with its contents completely defined by the form entity defined in the MDL.
- ::mdlListCollectorThis command will be used to create a list collector widget and this widget will be     attached to the data member specified in the argument. A list collector is a collector for more     than one type and each type has its selection managed independently. It is like a combobox of     collectors of different types and any selection made for each individual type is set     independently. For example, if the mdlListCollector is for a MultiRef member     (Point (pt) and Vector (vec)) data member, when the list collector is set to Point, the     selection is set and retrieved from the “pt” data member. When the list collector is set to     Vector, the selection is set and retrieved from the “vec” data member.
- ::mdlMatrixThis command will be used to create an mdlMatrix widget. It contains     a matrix of entry widgets based on the row and column numbers specified. If the number of rows     and/or number of columns are not specified, the dimensions of the matrix will not be     set.
- ::mdlNonLinearThis command will be used to create an mdlNonlinear widget, this     widget contains a combobox and it allows the user to specify a curve, spline3D, value or     expression properties based on the combobox selection.
- ::mdlOptionThis command will be used to create an option widget (combobox).
- ::mdlOrientationThis command will be used to create an orientation widget, which contains collectors,     list collectors, and combo boxes to allow the user to orient an entity. It also may contain a     “DC” button that presents the current orientation in a direction cosine dialog.
- ::mdlStringEntryThis command creates an entry widget associated with the data member handle specified.     The widget will provide an interface for the String data member allowing the user to modify the     stored string value. This widget does not link with an editbar. The associated data member value     is set to exactly what is displayed in the widget.
- ::mdlSymCheckBoxThis command can be used to create a mdlSymCheckBox widget which     will be attached to the “sym” data member (by default) of the pair entity passed as an argument.     The widget contains the necessary logic to prompt the user regarding copying values (from leader     to follower side) and/or breaking symmetry. It also contains common logic that is used to allow     or disallow the user from turning the symmetry on or off for an entity.
- ::mdlTableFormThis command will be used to create an mdlTableForm widget and this     will be attached to the table form entity passed as an argument. This widget will display the     “records” for a table form entity in rows of the mdlTableForm widget. The     individual cell contents are by default created based on the type of data that they contain.
- ::mdlTempCollectorThis command will be used to create a collector widget used to resolve a reference, but     this widget will not be attached to any entity data members. Instead, it will set and retrieve     the reference value from a Tcl variable. Like the mdlCollector widget, this     widget will let the user pick an entity of the allowed type either graphically or from a     tree.
- ::mdlTempFileNameThis command creates a widget that represents a filename value that is referenced by a     variable (not a data member of an entity).
- ::mdlTempListCollectorThis command will be used to create an mdlTempListCollector widget.     This widget is a collector that lets the user select multiple different types and hold on to     each reference individually. It is not attached to a data member so it gets/sets its value from     the specified variables. The widget is a “combobox” of mdlTempCollectors of     different entity types. The user can select the type of entity that they want to resolve and     then resolve it. The resolutions for the other types are not lost, they are individually     maintained. The list of types includes a variable to hold the value for each type. This widget     will not be attached to any data members.
- ::mdlTempMultiPickCollectorThis command creates a widget that allows the user to pick entities from a hard-coded     list that is presented in the graphical user interface. This could be used to limit the user’s     picks. The widget itself is composed of a collector that is used to set the pick mode (for     graphic picking), a list box that contains the available picks, and some convenience buttons to     select all/select none/toggle selection.
- ::mdlWizardDlgThis command creates a dialog designed to easily contain multiple “pages”, multiple     configurable buttons and a “built-in” message box to report messages.
- ::RegisterTypedAnalysisThis command registers a new customized analysis entity type in MotionView.
- ::SelectItemsThis command will select the item specified as an argument in the browser and will     display the respective panel. If more than 1 item is specified in the selection list, the items     are all marked selected in the browser, but the model panel is displayed.
- ::SetCurrentLRTabThis command is used to set which LEFT/RIGHT tab of a     panel is selected if any panel’s selected entity is a pair.
- ::ShowDetailsForThisEntityThis command is used to request if the entities contained within a registered entity     (container) are to be displayed in the browser.
- ::UpdateCurrentPanelThis command reloads the current panel for the current solver mode if a current panel     is displayed. If there was no panel displayed when this procedure is called, nothing happens. If     the solver mode was changed while a panel was displayed, this procedure will reload the panel     for the updated solver mode (in case the panel was solver-specific).
