*menuif()
Used to conditionally execute branches in the card image.
*menuif (expression)
HyperMesh Card Previewer Command
- expression
- A relational expression.
Requires an *menuendif() command.
The expression is required to be enclosed in square brackets.
The following operators are available:
| ==, = | equal |
| != | not equal |
| <= | less than or equal |
| < | less than |
| >= | greater than or equal |
| > | greater than |
If multiple entities are being displayed and an *menuif() returns conflicting results for the expression, the entire *menuif()/ *menuelse() / *menuendif() block is skipped.
