@namedentity()
Returns the value of the "Export as named entity" export option.
@namedentity()
HyperMesh Template Function
None.
Examples
Example:
*if([@namedentity()])
// Code for named entity export
*endif()
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021
