Data Entry and Access
Template files allow you to access information from the HyperMesh database with two methods, data names and attributes.
Template files use data names to access information from the HyperMesh database. A data name is a string that represents a piece of data. At output, HyperMesh replaces the data name string with the value that the data name represents. For example, a node has id, x, y, z, and system as possible data names in the template files. If you enter the command *field(integer,id,8) into a template file, HyperMesh outputs the node ID in an integer format using eight spaces.
A data name can also represent a pointer to another entity in the database. In the element data name list, the data name node1 is a pointer. node1 points to a node in the database. Using the command *field(integer,node1,8), HyperMesh issues the error message "field statement references a pointer". HyperMesh can’t output the correct value because node1 points to a node entity that has many different possible values. To print the node ID, reference the pointer as *field(integer,node1.id,8). A period separates the data name pointer node1 and the data name id.
*defineattribute(E,1,real,none)
*defineattribute(G,2,real,none)
*defineattribute(Nu,3,real,none)
*defineattribute(Rho,4,real,none)The template files also allow for advanced features to be defined from within the template like counters, tables and variables. This allows information to be passed from one function to another.
Comments can be added to the template using //. Add as many comments as needed to the template file in order to describe what is being coded and to allow other developers to follow your logic.
